ТЕМА: FT-817
FT-817 25 Янв 2015 19:30 #23194
  • Igor16
  • Igor16 аватар
кое-что проясняется:
forum.qrz.ru/ft-817/32790-cw-filtr-v-ft-817-a.html
5. You can go ahead and put the top panel and shoulder strap brackets back on and turn the rig back on. Press the "F" key and hold it for half a second to take you into menu mode. Turn the SEL dial until you get to menu #38. It should say "OP FILTER" and "OFF" just above that. Rotate the main tuning dial until you see "CW" (not "OFF" or "SSB"). Important note - as you go through the "SSB" choice, you will notice that the rig switches to the newly installed CW filter - DON'T PANIC, all is okay. This threw me for a while until I understood what was going on. Make sure that menu #38 is set to "CW" (ignore what the receiver actually does!) and then press the "F" key for half a second again to exit menu mode.
6. You're almost done. You will probably panic at this time (as I did!) because as you switch through the modes from USB/LSB/CW/CWR etc., the rig seems to be stuck in SSB filter mode. There's one more thing you have to do to get the CW filter working. Check out page 14 of your FT-817 Operating Manual - number 7 at the bottom right of the page you will see the "C-Key" setting for "NAR". You have to set this in order for the receiver to switch to the narrow CW filter when you switch the rig to CW or CWR modes. To do this, first put the rig into CW or CWR mode then tap the "F" key once quickly. The FUNC Keys menu items for the A/B/C pushbuttons should appear. Rotate the SEL control until you see "IPO ATT NAR" over the A/B/C buttons. Then press the "C' pushbutton once to set the filter to Narrow. A small right-pointing arrow should appear and the rig should switch to the CW filter - you should hear a marked difference in the receiver noise "tone".
7. That's it. You can swap between the SSB and CW filters anytime by revisiting the FUNC Key menu and toggling the NAR function.
только непонятно зачем нужны лишние манипуляции?
FT-817 19 Авг 2015 22:11 #25894
"Хозяйке" на заметку:
Portable and Emergency Power Considerations for the FT-817
FT-817 04 Окт 2015 10:41 #26581
  • r6ldf
  • r6ldf аватар
ub0wag пишет:
доброго времени суток.может вопрос не по теме,но мой 817 при работе на укв грееться это нормально?(питание от внешнего акумулятора)
Нормально.Я постоянно в поле на машине.Питание от а/м акк. Тоже греется если долго работать на УКВ.На остальных еле тёплый
FT-817 04 Окт 2015 10:55 #26582
  • r6ldf
  • r6ldf аватар
RW3XS пишет:
ev6dx пишет:
С 300гц-овым, конечно не сравнить. Но за неимением... plus.google.com/u/0/photos/+%D0%92%D0%B8...hkey=CNr5opGO6ce87AE
Я писал здесь о них : qrp.ru/forum/10-%D0%9F%D1%80%D0%BE%D0%BC...aoBao?start=50#21047
А 300 герцовый -то КРАСАВЧИК ! Как режет !
Как 300 герцовый улучшает приём на SSB? Ведь на 817-м можно в ручную резать полосу по ПЧ! Если можно подскажите чайнику.Я работаю в основном на SSB.
FT-817 04 Окт 2015 17:19 #26583
Никак.
FT-817 12 Янв 2016 15:19 #28279
  • UA1AFT
  • UA1AFT аватар
Для FT-817 хочу приобрести аккумулятор Ginzzu GB-1245 Напряжение 12 В емкость 4,5 А/Ч Мне аккумулятор понравился небольшим весом (1,58 кг) и габаритами (70 x 101 x 90 мм).
Вопрос к пользователям FT-817: не маловата ли емкость? Хватит ли, скажем, на 2 часа работы в спринте ?
FT-817 12 Янв 2016 15:25 #28280
  • rn6llv
  • rn6llv аватар
Не переживайте конечно же хватит, и еще останется. Главное что вес акуммулятора более-менее, у меня 7 А/ч уже тянет на 3 кг и это уже ощутимо, но тем не менее ваш вариант очень даже хороший.
FT-817 13 Янв 2016 01:33 #28290
  • UA1AFT
  • UA1AFT аватар
Спасибо.
Li-Po и подобные аккумуляторы - для наших TRX 26 Янв 2016 12:02 #28561
  • UR5LAM
  • UR5LAM аватар
Случайно наткнулся на интересный сайт.
Может кому полезно будет:
817companion.com/
Li-Po и подобные аккумуляторы - для наших TRX 26 Янв 2016 12:41 #28562
  • R2DEE
  • R2DEE аватар
Да, там есть интересный модуль для вывода панорамы, который размещается на месте фильтра. И вроде бы поинтересней, чем PocketRxTx, но, я, правда, не пользовался, потому что на мой телефон не ставится.
