Home Форум Клуб RU-QRP Самодельная техника NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz
ТЕМА: NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 02 Сен 2014 11:52 #20874
  • R1FW
  • R1FW аватар
Всем привет! Вот прикупил вот такой KIT:
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz SSB CW TRANSCEIVER KIT
Сайт производителя: blekokqrp.blogspot.ru/
Небольшое описание:
MICRO-40SCK QRP 3W SSB/CW TRANSCEIVER WITH NEW FEATURES by BlekokQRP-YD1JJJ
All the parts have been assembled and tested !!!!
With the addition of CW mode, this device is a dream of qrper's, such as
stable LO, QSK, true sidetone, RIT.
Micro40SCK is Micro40SC that has added new features that are needed by the operator. These features are customer wishes sent to us via email.
The new features are :
Simple AGC, to reduce the very strong signals .
Two bandwidth crystal filters, 2.3Khz or 1.2Khz
Socket for K14 or K16 CW/morse keyer (not included, optional), and the IC morse keyer can be purchased to k1el.tripod.com/
General Specification :
Frequency Coverage: 40M, 7.000-7.170Mhz (VFO) using diode varactor + potentiometer.
Micro40S also can shift from 7.00Mhz to 7.30Mhz only with ferrite adjustment, but only 170Khz in tuning range.
RIT or Clarifier, selected by togle switch, +/- 2Khz
SSB or CW mode, selected by togle switch
Power: 12-18VDC
receive 25mA (no signal), 200mA max, 700mA-1200mA on transmit.
Controls: Tuning, Volume, RIT/Clarifier
Antenna Impedance : 50 ohms
Board size: 70mm x 124 mm
RECEIVER Specification :
Single conversion superheterodyne. IF 5Mhz.
Sensitivity: 0.2uV
Selectivity: 2.3Khz or 1.2Khz, 4 pole crystals ladder filter (main) and 2 pole ladder filter (tail)
Audio output: 250mW, 8ohm, LOUDSPEAKER NOT INCLUDED
TRANSMITTER Specification :
RF Power Output: 3 - 6W PEP (12-18V)
Second harmonic output: -45dB.
Other spurios signals: -50dB or better.
Carrier suppressión: better than -35dB
T/R Switching: 1 Relay
Microphone type: electret Mic (no included).
BOX ENCLOSURE & EXTRA MICROPHONE ARE NOT INCLUDED.
Как я понял, что экземпляр тестовый, но уже есть неплохие результаты.
Думал это реальный KIT можно будет попаять, а оказалось что платка уже в сборе. Первая посылка пострадала, продавец без проблем отправил новый пакет, но забыл положить три переменных резистора на 10 К. На фото видно комплект. Потихоньку собираю. По результатам буду делиться тут.
Постепенно возникают вопросы, надеюсь на Вашу помощь.
1. На плате есть выход DDS, какую шкалу лучше подобрать? смотрел на ebay.
2. Перестройка по частоте, происходит с помощью резистора, я так полагаю что это очень грубая подстройка, что можно поставить для более плавной настройки. В некоторых DDS VFO есть энкодер, что скажете по этому поводу?
В некоторых роликах виден переменник синего цвета, что за номинал?
3. Какую схему S-метра применить? Нашёл вот такую шкалу [url=http://http://www.ebay.com/itm/Edge-Mount-S-SWR-RF-Power-Meter-Rare-Great-for-QRP-Transmitter-/291149329205?pt=US_Radio_Comm_Meters&hash=item43c9da3335][/url]
TX:Elecraft KX2
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 02 Сен 2014 14:59 #20875
RN3GW пишет:
Непонятно,там нет ни какой DDS,обычный гетеродин на НЕ602-й.
RN3GW пишет:
2. Перестройка по частоте, происходит с помощью резистора, я так полагаю что это очень грубая подстройка, что можно поставить для более...
Это 10-оборотный резистор на 20К. Лучше поискать советский ППМЛ на 20 оборотов.
Он дорогой,но серьезный,там пол-тонны драгметаллов.
RN3GW пишет:
Ну например такую
А со шкалой,все не просто,нужен серъезный буферный усилитель от 7-й ноги 602-й микросхемы.
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 02 Сен 2014 15:54 #20877
  • R1FW
  • R1FW аватар
Скан ТТХ:
TX:Elecraft KX2
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 02 Сен 2014 16:03 #20878
  • R1FW
  • R1FW аватар
Я правильно понимаю, что выхода EXT LO DDS, который есть на плате, не достаточно для шкалы?
TX:Elecraft KX2
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 08:27 #20885
интересное изделие!
а что за пластмассовая коробочка на фото?
и во сколько обошелся такой KIT?
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 08:55 #20886
RN3GW пишет:
Чот ,не могу его на схеме найти... :blush:
Вобще-то: EXT LO DDS можно перевести,как, внешний местный гетеродин DDS...
Это или опция,или для особо продвинутых...или для SDR модификации.
В схеме используется внутренний гетеродин микросхемы NE 602,причем
гетеродин,это весьма деликатный узел,даже при невысокой частоте гетеродина.
И подключение цифровой шкалы может привести к разнообразным неприятностям.
Чтобы их ,гарантированно,обойти,нужен нормальный буфер.
Если у Вас будет желание поморочить голову ;) то схему нарисую.
ЗЫ А схема в мануале отличается от той,которая на сайте... :blink:
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 10:25 #20888
  • R1FW
  • R1FW аватар
cudgel пишет:
интересное изделие!
Коробочка просто пищевая, для бутеров)))) там и была сама платка. Для транспортировки по почте. Обошёлся 79$ + 15 доставка. Периодически появляется на ebay? надо отслеживать.
TX:Elecraft KX2
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 10:30 #20889
  • R1FW
  • R1FW аватар
UT5LP пишет:
RN3GW пишет:
Если не ошибаюсь, у него на сайте именно этого экземпляра нет, там много других подобных. Эта первый экземпляр где есть и SSB и CW.
Спасибо Вам за схемы.
Подбираю корпус, крутилки и.т.д. Времени правда маловато на всё это дело))))
По результатам отпишусь.
TX:Elecraft KX2
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 11:03 #20890
RN3GW пишет:
cudgel пишет:
интересное изделие!
ОК, спасибо.
Вы на ebay брали?
а у автора напрямую можно заказать? не в курсе?
NEW MICRO-40SCK MICRO-40SC QRP 40M 7.000-7.170 Mhz 03 Сен 2014 12:06 #20891
RN3GW пишет:
Всё-таки,попробуйте найти ППМЛ 20К...НЕ ПОЖАЛЕЕТЕ!!!Реальнее всего его купить у скупщиков драгмета...(национальности перечислять не имеет смысла :whistle: )
У них наиболее ценные,маленькие номиналлы...до 1К.А в качестве образцов ,на бордах объявлений,висят,как раз менее ценные...
Выглядят оне...так...www.155la3.ru/ppml.htm
или так
