ТЕМА: Curumim with TL431 audio amplifier
Curumim with TL431 audio amplifier 09 Окт 2022 09:09 #58765
  • ili
  • ili аватар
Hi, my name is Emilio from Mexico. Thanks for accepting me in the forum, and sorry for write in english i dont know russian languaje. I love your club and your experiments. I wanna share one version of curumin transceiver from PY20HH:
I dont have a crystal socket so make one with two small pieces of wood and tin from deodorant spray:
Here is the complet circuit i use shunt voltage regulator integrated TL431 like audio amplifier:
The output voltage with 50 ohms load is about 3 volts, calculate the power about 180mw.
72!!
Curumim with TL431 audio amplifier 09 Окт 2022 09:18 #58766
Hi,Emilio! Very interesting information, thanks! We will be glad to see You on the forum.
Curumim with TL431 audio amplifier 09 Окт 2022 10:45 #58767
Dear Emilio, thanks for your radio presentation ,hopes to hear your signal and qso will occur!
In qrp we trust!
Curumim with TL431 audio amplifier 09 Окт 2022 11:11 #58768
  • RG1L
  • RG1L аватар
Dear Emilio, welcome!
Curumim with TL431 audio amplifier 09 Окт 2022 15:57 #58775
Dear Emilio, thanks for start the interesting topic! I enjoy the simplest radios very much. Years ago I assembled Pititico TRX by PY2OHH with 3200 Ohms phones but no one result in RX mode. Next, I add audio amplifier LM386 and a lot of stations was copied as "pile-up" stile, BC and HAM heard at once.
Эмилио, спасибо за интересную тему! Я очень люблю простейшие конструкции. Несколько лет назад я пробовал трансивер PY2OHH Pititico с наушниками 3200 Ом, но никакого приема не була. Добавив УНЧ на LM386 услышал множество радиостанций одновременно, как вещательных, так и любительских.
The same so trcvr designed by HA4OO. I tried it also but no success in RX.
Аналогичная конструкция трансивера HA2OO. Я пробовал ее, но также без успеха на прием.
Similar trcvrs available at G3XBM (Chirpy, XBM-series) and other designers.
Подобные конструкции есть также у G3XBM (Chirpy, серия XBM) и у других конструкторов
Emilio, I'm happy to subscribe to your topic, it's interesting so much and must be to continued. GL for you!
С удовольствием подписываюсь на эту тему, это очень интересно и должно иметь продолжение. Успехов!
Curumim with TL431 audio amplifier 09 Окт 2022 18:38 #58776
  • Марауль
  • Марауль аватар
Hello, dear Emilio! Very amazing and non-standard idea to use TL431 as audio amplifier!
It is very interesting to hear how the receiver of your TRX sounds. Do you have the opportunity to make a record, please?
Curumim with TL431 audio amplifier 10 Окт 2022 02:48 #58777
  • ili
  • ili аватар
I make the record and share.... the amplifier work amazing.
Curumim with TL431 audio amplifier 11 Окт 2022 03:34 #58785
  • ili
  • ili аватар
There is the audio recorder from the curumim transceiver and the TL431 like audio amp with the 7055khz cristal at 00:00 utc aprox.
The distance between my QTH and the CW tx (from USA) is about 1,800 kilometers distance.
sbj.edu.mx/curumim/curumim-7055-mx.mp3
I dont know why is this "mmmm" sound, perhaps some impedance problem between the transistor oscillator and the Audio Amp.
My sound recorder is a Sony ICD-UX200, my antenna is a long wire about 20 meters and 10 meters tall.
72
Curumim with TL431 audio amplifier 11 Окт 2022 09:15 #58790
Thank you very much for audio, dear Emilio! I think, the "mmmm" hum (noise) occurs due to the arrival part of the oscilator signal at the antenna input. Anyway, it's very interesting. Emilio, are you planning to add var cap + inductor in series with xtal to have +/- some kHz VXO?
Большое спасибо за запись, Эмилио! Я думаю, что гудящий шум возникает из-за частичного проникновения сигнала генератора на антенный вход. В любом случае, это очень интересно. Эмилио, ты планируешь добавить КПЕ с катушкой последовательно с кварцем для небольшого изменения частоты?
Curumim with TL431 audio amplifier 14 Окт 2022 05:40 #58809
  • ili
  • ili аватар
Hi, i try put a 1n4007 silicon diode like varactor but no have more space for the potentiometer perhaps tomorrow "reuse" old TV and extract some small pots...
72
