The 1 Watt Game 04 Окт 2026 19:49 #65997
от OO7Z
The 1 Watt Game 16 Окт 2026 11:56 #66024
В субботу 17 октября 1 ватт игра. Приходите поиграть!
THE 1 WATT GAME 2026 - PART2.
I. OBJECTIVE: A short QRPP CW game on the 20 meterband. All radio amateurs and SWL's are cordially invited.
II. DATE: Saturday 17 Okt 2026 from 0900 to 1200 UTC.
III. BAND: 20 meter band only. 14.060 MHz +- 10 kHz.
IV. POWER: maximum 1 watt.
V. OPERATION: Only CW (A1A).
1. CALL: CQ 1W
2. EXCHANGE: RST / POWER / LOCATOR
ie. 559/1w/ JO21LA. Additional info like power, RTX, antenna,... is welcome.
VI. SCORING:
First calculate the distance of each QSO.
QSO points = distance divided by the power of the other station (in watts).
Power less than 1 watt is equal to 1 watt in the points calculation.
Eg. your counter station is 2000 km away and uses 5 watt. Then the point count for this qso is: 2000/5 = 400 points.
Eg. your counter station is 3000 km away and uses 1 watt. Then the point count for this qso is: 3000/1 = 3000 points.
Eg. your counter station is 3000 km away and uses 300 milliwatt. Then the point count for this qso is: 3000/1 = 3000 points.
TOTAL SCORE: Sum of all QSO points.
The use of simple antennas is highly recommended.
VII. LOG SUBMISSION:
Email your score to Этот e-mail адрес защищен от спам-ботов, для его просмотра у Вас должен быть включен Javascript ( ! NEW EMAIL ADDRESS ! )
Add the text: Me, (your call) , I declare that I managed a total of XXX QSOs, my total result is XXX points.
Please add your best DX (call and locator) station-info: locator, power, RTX, antenna. Pictures of your set-up are appreciated.
VIII. GAME REFEREE: Peter Kempenaers (ON6KZ/OO7Z). The Game Referee has the right to request full log in case of any doubt.
X: Nominees: award for the winner, the best DX, funiest location (if outdoor), original home brew, lowest power.
The 1 Watt Game 17 Окт 2026 23:24 #66025
К игре 1 Ватт подключился из загородной локации VL-23 примерно в 10:00z, использовал антенну от маяка, солнечно и до +17 °C.
Трансивер FT-817, мощность 1 Вт, диапазон 20М. Шумы на приёме S=8...9 особенно возросли в последний час игры. Слышал: F4NPL, PA0CMU, DL0VLP,не дозвался, но, похоже, RA7R удалось вызвать PA0CMU,
и ещё кто-то отвечал для RX3PR. На мой CQ течении двух часов так никто и не подошел. Скиммеры показывают споты 2...29 дБ только для последнего часа игры, прохождение улучшилось?! В моём логе: RA7R, R4WAN. Самая дальняя связь с RA7R: 1324.5 км.
Юрия слышал громко, Андрея слабее, записи прикладываю.
